Hello again all. As the political season is creeping up, I am trying to integrate NewsTicker information to ROSS XPression Studio. For right now, I have them working together quite well and everything showing up as needed, I'm just missing what seems to be simple knowledge of how to make some of this magic work.
So basically, what I have NewsTicker doing is showing the candidate name and to append the race of the candidate at the end of their last name (i.e. John Doe, R)
I have a bar graph that takes the percentage of votes and will scale the bar vertically from 0% to 100%, depending on that value. But the bars are colored and need to scale to the appropriate race, so the red bar scales up with republicans, the blue bar scales up with democrats, etc.
Is there a way to script what bar ties with which name, depending on what race is appended on the end of the name? Because right now, whichever candidate has the most votes is on top, and right now I have the top vote percentage tied with the red bar, the second one is ties with the blue bar, and the third is tied with a white bar, which, depending on which candidate has the most votes, needs to be visually accurate color-wise. Any tips? Do I need to be clearer? Everything right now is done through visual logic.
