  • 1.  Tweet Full Screen with Picture
    Posted 06-06-2017 14:38
    Hello all,
    I have a full screen tweet template that includes 140 characters (max) of text with a picture. The tweets are linked to an XML and cycles through via %relid%. I wanna be able to use the same template do that when a tweet with a photo shows up the tweet text would move to the right with the photo show up on the left, and when the next tweet shows up without a photo, the tweet text would take up the whole full screen. Also, I want the tweet text to only reach a certain limit on the bottom of the full screen so it doesn't go past the border. Any kind of help would be deeply appreciate it. Thanks
  • 2.  RE: Tweet Full Screen with Picture
    Posted 06-06-2017 15:53
    You could cheat it and save yourself some heavy lifting by setting the default image to be a Twitter logo, so when the XML returns no image, its just the bird image.
    As for the text, just put an auto squeeze on the text and build your template for 200 characters and you'll never run out of room.
    Edit: Also, check the 'Max Height' thread that was recently bumped for another solution.
