I'm wondering why the title generated text with shadow is looking weird during the alpha transition out?
I made one test (attached) using text object and one transparent bitmap.
As you may see, the XPression generated text with shadow is looking like the bitmap when Alpha is 100%.
When the Alpha is going down (like Alpha goes to zero for fade out transition) the generated text without shadow is looking good but the text with shadow is showing the shadow in face text and it doesn't mach the bitmap output.
There is a fix for this issue?
