  • 1.  Change Datalinqs to Static Text for Images
    Posted 09-28-2017 23:16
    Hello all, I have some scenes that display twitter comments and avatars (via Datalinq xml file) which works great! The producer now wants to be able to save some tweets for a backup purpose. I use the "Change Datalinqs to Static text" command which works great on the text but makes the avatar go away. Is there even a way I can convert the datalinqed avatar image into a static image? Maybe via scripting? Thanks.
  • 2.  RE: Change Datalinqs to Static Text for Images
    Posted 10-10-2017 18:58
    Unfortunately that isn't possible right now.
    Can you export the graphic out of XPression as a still image (PNG/TGA) instead for backup purposes?
  • 3.  RE: Change Datalinqs to Static Text for Images
    Posted 05-20-2022 17:06
    I know this thread is older but it is the closest issue I could find to my question.
    I there an scripting option available to change between the "WIDGET" tab and the "STATIC" tab in the Take Inspector for a Published Text Object?
    I have a large number of Take Items tied to Widgets in my sequencer and I would like to script a macro that switches a specific Text Object from Widget to Static.
    Nico Gomez
  • 4.  RE: Change Datalinqs to Static Text for Images
    Posted 10-12-2017 17:15
    That's exactly what we ended up doing. Thanks garner.
