So our truck is away for the next little while so I'm not able to try this, but I sort of need to get started on it right away, hence the forum question...
Is it possible to play multiple scene directors at once? Or will one just interrupt the other?
We have 5 videos that will be on screen at once, and each one needs to be paused and played back on command (and playback will overlap quite a bit) So I'm thinking each video material will live in its own scene director with the pauses built in. And we'll use widgets linked to text objects with "resume" scripts.
Will this work? I'd try it myself but like I said, the truck is gone :(
