We have buit a new Xpression system, with all the hardware specs from the Ross website, to have a Text-TV an visual radio solution.
But at nights, the Xpression.exe stops responding to windows.
This is the message from the event log.
The program XPression.exe version 5.9.0.3132 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel.
Process ID: 1da0
Start Time: 01d18ca4ee408bc2
Termination Time: 103
Application Path: C:\Program Files (x86)\XPressionStudio\XPression.exe
Report Id: 1a68f65d-f965-11e5-8ed3-0cc47a48e32f
i can send crashdumps also if needed
maybe anyone here has an idea what this might be? On our second Xpression The program keeps running 24/7, there is no problem :S
regards
Jan Augenbroe
