  • 1.  Automatically Stepping Through Records in an XML File
    Posted 11-14-2014 19:38
    I am trying to find a way to step through records in an XML file automatically. I am able to accomplish this manually using the DataLinkKey option. Is there a way to increment the DataLinkKey value automatically with a 3 second or so delay between increments?
  • 2.  RE: Automatically Stepping Through Records in an XML File
    Posted 11-28-2014 20:18
    For our election, I stepped through items on an XML feed, by using the %relid% along with a timed sequence. We were able to use only certain XML items and not others, by renumbering the sequence items to match the XML items. Check this link for instructional videos. http://xpression.rossvideo.com/videos/
