  • 1.  Designer to GO
    Posted 05-09-2015 09:12
    Can I create templates using Xpression Designer and play out on Xpression Go ?
    Are there any limitations ?
    Joe
  • 2.  RE: Designer to GO
    Posted 05-09-2015 09:28
    Yes you can...
    No limitations...
  • 3.  RE: Designer to GO
    Posted 05-09-2015 13:03
    Just use the Export option in the File Menu on designer to package your graphics into an XPP file, then transfer that to Go and deploy it there.
    The GO system will take more performance to play out the templates so the performance meter will be much higher than it is on the Designers virtual output; so you need to make sure you benchmark the graphics performance on a GO system.
  • 4.  RE: Designer to GO
    Posted 05-10-2015 01:42
    The only limitation that you will have is with Datalinq. If your Go is not licensed for Datalinq but you built templates in Designer that are to use this you will not be able to access these outside data sources.
