Hi, I'm trying to do this as well, but I'm having trouble. I get an error that the file is not found. Is there something I should be doing with the file path? I tried to use a material name and there was still nothing in the quad. I have a quad with the material source set to Datalinq with the datalinq field in dashboard that has the filepath in it.
Any suggestions?
