I have a page with a multi-team setup. The teams in play could literally be any team, so it falls a little outside our normal Home Team / Away Team setup page. I could accomplish what I am looking to do if I could set up a VL which would look at the material assigned to a face, and change the color of another element to generic white with said material assignment were anything other than 'Home Primary'. I was hoping the logic node 'equal to' would be up to the task, but it is only setup to accept integers. I have a work around, but I find it inelegant, so I thought I'd ping it off you all here to see if there is a node I've overlooked.
Cheers
- Willie
