  • 1.  Video in iNews
    Posted 07-23-2015 16:51
    We made a lowerthird that has replaceable video. Is it possible to replace that video through the Xpression Plugin in iNews? Or is only to replace images?
    Thank you in advance.
    Mildred
  • 2.  RE: Video in iNews
    Posted 07-27-2015 06:21
    If you select the published object field in the plugin and hit the second 'browse' button it will open a windows explorer window where you can select videos. It's the button beside the one you would select for images.
    The video will take on the attributes of the material's video shader that is already assigned to the object. So if you want it to loop put a dummy video material with the shader set to 'looping' on it.
