I am working on some scenes in our XPression to use in the NLE plug-in (which I am testing to see if we are going to use).
I have noticed that I cannot use automatic line break if the text have a right alignment. So I wrote a VB script to do the line breaks, and now I discover that Font Change Macros (eg. "Text {2}here") is not supported then using scripts.
Even a simple script where I assign a text property to another will remove the Font Macros, like the one below:
[FONT=courier new]dim text as xpTextObject
dim newText as xpTextObject
Self.GetObjectByName("text",text)
Self.GetObjectByName("NewText",newText)
newText.text = text.text[/FONT]
So what to do?
I really want to use the NLE plugin, but I need to use Font Macros and automatic line breaks at the same time.
