  • 1.  Text justify around decimal point
    Posted 03-19-2015 16:07
    Is there a way to justify text around the 3rd last character? I have a bunch of data which have a decimal in them. They are being displayed on chart. These numbers are stacked on top of each other. I would like all the decimal points to line up with each other. All the data have been rounded to two decimal places, but because of the nature of the font the decimals don't always line up.
    Any help would be appreciated.
    Regards,
    Rich
  • 2.  RE: Text justify around decimal point
    Posted 03-19-2015 17:08
    In the Object Inspector, in the Tabs & Options tab, set the #1 tab to DOT. All your numbers should line up by the decimal point.
  • 3.  RE: Text justify around decimal point
    Posted 03-19-2015 18:22
    Thanks Steve!
    Never knew that option was in there.
