Recently, I had a scene with a clock that when it reached o:oo it needed to dissolve away and dissolve on different text, of which were in two separate groups.
I made a VL that I thought would do this for me automatically. But for some reason it did not work.
Basically, I used a String Compare block that when clock is 0:00, compare to String Value (0:00), play CHANGE TEXT Scene Director. When clock reaches 0:00 the String Compare block Equal outputs 1 but the CHANGE TEXT Scene Director does not play. Not sure why? Any thoughts?
