I want to create a short ticker and run in loop, having as a background one bar and easy edit text from sequencer.
The message is short, something like: "COMMERCIAL BREAK >>> " and the ticker should be endless like: COMMERCIAL BREAK >>> COMMERCIAL BREAK >>> ...
1. If I have one crawl scene group with background bar in parent scene and text in child scene, the crawl have a huge break at the end even if the scene group is in loop mode, blank page at the start and end is unchecked.
2. If I make the crawl from sequencer (playout mode group: crawl) I have the same break at the end and no background bar here.
The single solution is 1st solution but having a longer text (multiple inputs of the same text) and having more than 1 child => is hard to operate.
Any sugestion?
