Hello support
I have a little bit of an urgent problem and don't know how to solve it. In my xls table there are two columns with times I need to access. In Excel, both columns are formatted as time (hh:mm:ss) and appear correctly - but inside XPression however, when accessing the data through datalinq, somehow the "null"-date of Excel is added in front of the time and the time now appears like this:
30.12.1899 00:26:11
instead of:
00:26:11
Since my client uses XPression Prime I can't solve this issue with a script. I've tried different formatting in Excel, but it won't do the trick. Is there a parameter in datalinq I need to change?
Thank you in advance
Remo
