  • 1.  Losing assets after packaging
    Posted 07-24-2015 15:33
    Today I made a package to transfer a project to the control room.
    This time however, the Xpression still complained about unfindable assets.
    I don't understand this: when you deploy a package, it should be asset link hassle free, should it not?
  • 2.  RE: Losing assets after packaging
    Posted 07-27-2015 06:16
    If you check the project on the system you are exporting from, do the assets(materials) that show errors on your on-air system present in the file paths specified by the design system?
    It sounds like the assets aren't there when the package is initially made.
  • 3.  RE: Losing assets after packaging
    Posted 07-27-2015 13:01
    I think the user made a mistake: he unfolded the package on our network. It did unfold and made folders and a project but the folders were not filled with the assets. I think he has no rights to write on the network anyway so the folders being there, is a miracle already. I'll try see what happens when the package is unfolded on the data drive of the receiving xpression.
