  • 1.  XPression - Text Spacing
    Posted 09-02-2015 19:40
    Hey all,
    Sounds like a simple question but I'm having trouble spacing text horizontally. When I change the value nothing happens is there something I might have turned on on the scene font I need to turn off? Could it be the font itself is not compatible?
  • 2.  RE: XPression - Text Spacing
    Posted 09-02-2015 21:18
    Are you using the H-Spacing value or the Kerning value? Kerning only affects certain letter pairs (and only when the font supports it). H Spacing should work with any font and affects the space between all letters.
    Have you tried a different font to see if it works?
