  • 1.  Default material color with coding
    Posted 10-02-2017 17:58
    So I have 4 materials, one black, one blue, one red, one green. The default one is black.
    If a text field = R the red one should be shown
    if a text field = D the blue one should be shown
    if a text field = G the green one should be shown
    If a text field = ANY OTHER LETTER OR SYMBOL, it should be the black one.
    I have this working using coding, but I can't get it automatically default back to black if say an M or a Z is placed in the text field. It just stays whatever color was there previously.
    Here's the coding.
    dim right_cand_bg_black as xpBaseObject
    dim right_cand_bg_red as xpBaseObject
    dim right_cand_bg_blue as xpBaseObject
    dim right_cand_bg_green as xpBaseObject
    self.getobjectbyname ("right cand bg_black", right_cand_bg_black)
    self.getobjectbyname ("right cand bg_red", right_cand_bg_red)
    self.getobjectbyname ("right cand bg_blue", right_cand_bg_blue)
    self.getobjectbyname ("right cand bg_green", right_cand_bg_green)
    if right_cand_party.text = "D" then
    right_cand_bg_black.visible = false
    right_cand_bg_red.visible = false
    right_cand_bg_blue.visible = true
    right_cand_bg_green.visible = false
    elseif right_cand_party.text = "R" then
    right_cand_bg_red.visible = true
    right_cand_bg_blue.visible = false
    elseif right_cand_party.text = "G" then
    right_cand_bg_green.visible = true
    elseif right_cand_party.text = "I" then
    right_cand_bg_black.visible = true
    elseif right_cand_party.text = "L" then
    elseif right_cand_party.text = "" then
    end if
    EDIT: Nevermind, figured it out, had to include an ELSE at the end of it all.
  • 2.  RE: Default material color with coding
    Posted 10-03-2017 14:05
    You can do this very easily with visual logic. See my image attached.
