  • 1.  Scripting Image changes
    Posted 06-22-2017 20:34
    Hi everyone,
    I'm having a minor issue with scripting image changes.
    Here's the scenario: I've set up a scene where the images take their filename from a text field, then applies it to a quad. That works for the most part.
    I then have some visual logic that will sort those filenames based on a "rank" of where the new positions should be, and the script will make the changes. The problem I'm having is that when the script runs, it will make the changes correctly, but the images will flicker a bit between what was previously there and the newly applied image. I've tried many different alternatives. At first I thought maybe it was the Visual Logic causing it so I tried a different approach, but all had the same issue. The script runs when the scene is sent Online, then it's also set to run OnPreviewRender. I've also tried using it on one of the text layers that changes and all produce the same result of flickering as it changes.
    These are my system specs:
    Windows 10 64bit
    16gb RAM
    Nvidia GTX 660
    Xpression Developer 6.5 Build 3639
    Could it just be an issue with the Virtual Output?
    I can't include the scene file, but here's the script:
    Dim ChoiceCount As xpTextObject
    Dim QuestionFormat As xpTextObject
    Dim headshot as xpBaseObject
    Dim HSFile as xpTextObject
    Dim FilePath as String
    Dim CurrentPOS as String
    Dim ChoicePOS As xpTextObject
    Self.GetObjectByName("Choice Count", ChoiceCount)
    Self.GetObjectByName("Format", QuestionFormat)
    Dim index As Integer
    For index = 1 to ChoiceCount.Text
    Self.GetObjectByName("HS" & index.ToString() & " File", HSFile)
    If QuestionFormat.Text = "rank_pick" Then
    Self.GetObjectByName("Choice " & index.ToString() & " POS", ChoicePOS)
    CurrentPOS = ChoicePOS.Text
    Else
    CurrentPOS = index.ToString()
    End If
    Self.GetObjectByName(ChoiceCount.Text + " Rank HS" + CurrentPOS, headshot)
    FilePath = Engine.ProjectPath & HSFile.Text
    headshot.SetVolatileTextureFile(0, FilePath)
    Next
  • 2.  RE: Scripting Image changes
    Posted 06-23-2017 00:08
    Have you tried running the script in the OnBeforeOnline event instead?
  • 3.  RE: Scripting Image changes
    Posted 06-23-2017 03:27
    I haven't, but would that allow the data to continue to update?
  • 4.  RE: Scripting Image changes
    Posted 06-23-2017 03:30
    Or are you saying to continue using OnPreviewRender as well as switching from OnOnline to OnBeforeOnline?
