i've created a lower thirds but i wanted to link stats to the L3. iI have a xml file that i am linking it to but when players stats are put on the xml file they sorta go all over the place. they show up on the xml as a player but only once they receive a stat. they are arranged by jersey number. if a player with a lower number gets a stat then it input them above other names. currently i have the name, number and position linked to a .xls sheet, but for the stats those come from the xml file live during the game.is there a way to tell expression to look for the uniform number and use the info associated with it? attached is some screen shots.
