I tried using this script and it appears to only move the whole thing, no matter how many lines it is. I've adjusted the number I put with the "Self.PosY = " lines, but the only one that seems to make a difference is on the
" iflinesCount = 1 then
Self.PosY = ... "
section. When I change that number it moves, but when I have more than 1 line, it just puts the next lines under it, without changing the Y position of both lines (or more).
Any suggestions?
