  • 1.  Autosize picture "“ help with some maths
    Posted 06-25-2014 15:12
    I'm trying to modify a script that sets the scales an image to the maximum width/height based on the widthset/heightset variables. I'd like to be able to scale the image to a minimum width/height but I can't wrap my head around the maths.
    [CODE]'get aspect ratio
    picMat.GetDimensions(imageWidth, imageHeight)
    aspect = imageWidth / imageHeight
    'This the code I'd like to edit so that if minmax="MIN" it will scale an image to a minimum width or height
    if ucase(minmax)="MAX" then
    if imageHeight > imageWidth then
    scaleY = heightset / currHeight
    scaleX = (heightset * aspect) / currWidth
    else
    scaleX = widthset / currWidth
    scaleY = (widthset / aspect) / currHeight
    end if
    end if
  • 2.  RE: Autosize picture "“ help with some maths
    Posted 06-25-2014 18:52
    It seems to be behaving better on my second attempt. I don't know why I was having such trouble. I set up the script so that the ScaleX/ScaleY equations in each 'if statement' mirror each other and moved the calculation of the aspect ratio into the 'if statements', and I made sure the aspect ratio calculates to be 1 or greater. This cleared up some confusion for me and for whatever reason it started working correctly.
    else if ucase(minmax)="MIN"
    if imageHeight < imageWidth then 'Apply calculate final dimensions
    else
    aspect = imageHeight / imageWidth
    scaleY = (widthset * aspect) / currHeight
    end if
    else
