  • 1.  XPression - XML (RSS Feed) DataLinq Key Tutorial
    Posted 11-25-2014 14:41
    Hi all,
    Quick question: The XML DataLinq key tutorial that ROSS has provided shows you how to set up a key, but only with an actual XML file. Where as we are running XML statistics but over an RSS URL, so it looks differently than the XML stats in the tutorial ROSS produced. Can anyone explain this better or provide some documentation that better explains setting up the key in the "Set DataLinq Properties" window? Thanks!
  • 2.  RE: XPression - XML (RSS Feed) DataLinq Key Tutorial
    Posted 11-25-2014 19:17
  • 3.  RE: XPression - XML (RSS Feed) DataLinq Key Tutorial
    Posted 12-01-2014 13:40
    @garner does this only apply to elements represented by numbers or can this be text as well?
  • 4.  RE: XPression - XML (RSS Feed) DataLinq Key Tutorial
    Posted 12-01-2014 20:48
    To my knowledge - and from what I've tried, Datalinq keys themselves can only be numerical values.
    However - the content displayed from the Data Source feed can be any string.
  • 5.  RE: XPression - XML (RSS Feed) DataLinq Key Tutorial
    Posted 02-12-2015 03:44
    Where can I find the tutorial that you mentioned about setting up an XML Datalinq key? I am having a lot of trouble using only the information provided in the documentation.
  • 6.  RE: XPression - XML (RSS Feed) DataLinq Key Tutorial
    Posted 02-12-2015 17:02
  • 7.  RE: XPression - XML (RSS Feed) DataLinq Key Tutorial
    Posted 02-13-2015 12:20
    Is it possible to use these Keys with ADOOB Datalinq to Excel as well? And is it possible to adress more than one parameter in the Datalinq properties with scripting?
    We need to change "Row" and "Table" with a MOS published text. Is that possible?
  • 8.  RE: XPression - XML (RSS Feed) DataLinq Key Tutorial
    Posted 02-13-2015 13:07
    Yes, there are some helpful videos here: http://xpression.rossvideo.com/videos
  • 9.  RE: XPression - XML (RSS Feed) DataLinq Key Tutorial
    Posted 02-13-2015 15:04
    Thank you for the link Brain. It brought me pretty far, but now my script is not working. Maybe you can help me out:
    dim AbstimmungNr as xpdatalinqkey
    dim AbstimmungWert as Integer
    self.getkeybyname("Abstimmung-Nr", AbstimmungNr)
    AbstimmungWert = AbstimmungNr.toInt + 5
    AbstimmungNr = AbstimmungWert.toString
    I just want to add 5 to the Datalinq Key value. is that possible?
  • 10.  RE: XPression - XML (RSS Feed) DataLinq Key Tutorial
    Posted 02-13-2015 15:26
    The error is on the self.getkeybyname line. I'm not sure what self is, is that the Scene? (it depends where your script is located)
    From the xpScene you first need to call GetDatalinqKeys, then from that object you can call GetKeyByName.
  • 11.  RE: XPression - XML (RSS Feed) DataLinq Key Tutorial
    Posted 02-13-2015 15:46
    Yes, the script is located on the scene, so self is referring to the scene. I'm not sure how I call the GetDatalinqKeys. I tried following:
    self.GetDatalinqKeys("ABSTIMMUNG KANTON")
    ABSTIMMUNG KANTON is the name of the scene. Could you pleas make an example how to call up the Keys?
