hello I have the following error, I have used the transition logic example script from ross to adapt it but I have one big problem: the photos change before the change between pages is made. The other problem is that I have a lower third that is checking for this graphics to enter on layer 4, but to make it work, I set this script to run on take Item layer 3.
this is the script so you guys can take a look at it, thank you in advance. I just want to know why the text behave correctly (the old text leaves before the new text enters) but the images change when my second scene enter online.
dim j, k as integer
dim distritoIN, distritoOUT, debug, conteo1, conteoP, tipo_lugar, cod_lugar as xptextobject
k = 3
dim foto(k) as xpquadobject
dim mat as xpMaterial
dim shader as xpBaseShader
dim dirfoto(k) as string
dim candfoto(k) as xptextobject
self.getobjectbyname("tipo_lugar", tipo_lugar)
self.getobjectbyname("cod_lugar", cod_lugar)
self.getobjectbyname("distritoIN", distritoIN)
self.getobjectbyname("distritoOUT", distritoOUT)
self.getobjectbyname("conteo1", conteo1)
self.getobjectbyname("conteoP", conteoP)
self.getobjectbyname("debug", debug)
for j = 1 to k
self.getobjectbyname("foto" & j, foto(j))
self.getobjectbyname("candfoto" & j, candfoto(j))
next j
j = 0
distritoIN.text = UCase(distritoIN.text)
distritoOUT.text = distritoIN.text
if conteoP.text = "" then
conteo1.text = conteo1.text
else
conteo1.text = conteo1.text & " " & conteoP.text & "%"
end if
for j = 1 to k
dirfoto(j) = Engine.ProjectPath & "fotos" & tipo_lugar.text & "" & cod_lugar.text & "" & candfoto(j).Text & ".png"
foto(j).getmaterial(0, mat)
mat.GetShader(0, shader)
shader.SetFileName(dirfoto(j))
next j
j = 0
'debug.text = dirfoto(1)
Dim OutputFB as xpOutputFrameBuffer
Dim OutgoingCG as xpScene
Dim InSD, OutSD as xpSceneDirector
Dim InTrack, OutTrack as xpSceneDirectorTrack
Dim todoIN, todoOUT, dataIN, dataOUT as string
Dim LayerMoveDirection, i, FB, Layer as Integer
todoIN = "todoIN"
todoOUT = "todoOUT"
dataIN = "dataIN"
dataOUT = "dataOUT"
LayerMoveDirection = 1
Self.GetOnline(FB, Layer)
InSD = Self.SceneDirector
i = 0
InSD.GetTrack(i, InTrack)
Do
InTrack.Enabled = False
i = i + 1
Loop While InSD.GetTrack(i, InTrack)
Engine.GetOutputFrameBuffer(FB, OutputFB)
If OutputFB.GetSceneOnLayer(Self.DefaultFramebufferLayer + 1, OutgoingCG)
OutputFB.MoveLayer(OutgoingCG.DefaultFramebufferLayer + 1, OutgoingCG.DefaultFramebufferLayer + 2)
OutputFB.MoveLayer(Self.DefaultFramebufferLayer, Self.DefaultFramebufferLayer + 1)
OutSD = OutgoingCG.SceneDirector
i = 0
OutSD.GetTrack(i, OutTrack)
Do
OutTrack.Enabled = False
i = i + 1
Loop While OutSD.GetTrack(i, OutTrack)
If InSD.GetTrackByName(dataIN, InTrack) = False then
InSD.GetTrackByName(todoIN, InTrack)
End If
If OutSD.GetTrackByName(dataOUT, OutTrack) = False
OutSD.GetTrackByName(todoOUT, OutTrack)
End If
Else
End If
InTrack.Enabled = True
OutTrack.Enabled = True
InSD.Position = 0
OutSD.Position = 0
InSD.Play
OutSD.Play
