  • 1.  Play widget timer/clock from Dashboard
    Posted 03-21-2015 22:46
    Does anyone know if Dashboard is able to reset, start & stop a timer/clock widget? If so how would you go about doing that?
  • 2.  RE: Play widget timer/clock from Dashboard
    Posted 03-23-2015 15:27
    Hi Chris.
    Yes, you can do this.
    In XPression:
    -Create a script action that updates the timer/clock the way you want in XPression and attach that to a Ross Talk GPI message in the keyboard/GPI mapping menu
    In DashBoard:
    -In a custom panel that you create, simply add a button for every script you want to trigger remotely and attach a RossTalk GPI task to that button.
    Troy.
  • 3.  RE: Play widget timer/clock from Dashboard
    Posted 06-10-2015 01:00
    I have the same purpose too
    but I'm not familiar with code
    If you don't mind could you please write the script for button
    1. (start, reset) timmer. and
    2. (up & down) Counter
    I want move this button into Dashboard.
    - do I put the code on the "script event properties"?
    Thank You
