Render View Text Editing in Other Scenes
  • 1.  Render View Text Editing in Other Scenes
    Posted 02-12-2016 16:02
    Hey all,
    If I have a render view, is it possible to edit the text within a render view material that is being used in another scene? Visual Logic, Scripting possible here?
  • 2.  RE: Render View Text Editing in Other Scenes
    Posted 02-12-2016 16:58
    Datalinq would be the easiest way. Just Datalinq the text in your renderview scene.
  • 3.  RE: Render View Text Editing in Other Scenes
    Posted 02-12-2016 19:03
    @garner I see where you're going but are the keys for that render view going to be available in the new scene I am taking those render views into?
  • 4.  RE: Render View Text Editing in Other Scenes
    Posted 02-13-2016 00:40
    Since the renderview scene is hardcoded into the material; you can access it via scripting. Just do a GetSceneByName("SceneName", scene, false) to get the pointer to the scene then you can change any text/data in it that you want..
  • 5.  RE: Render View Text Editing in Other Scenes
    Posted 02-15-2016 18:41
    Cool! And that's just a script I'll have to put on a single event in the Scene Director, no?
  • 6.  RE: Render View Text Editing in Other Scenes
    Posted 02-17-2016 19:40
    You'd probably be putting it in an OnSetText of a text object. So when an invisible text object in your online scene was was updated it would write to a text object in the renderview.
  • 7.  RE: Render View Text Editing in Other Scenes
    Posted 02-17-2016 19:49
    @garner, gotcha. The only thing I'm worried about is that I have over 14 text objects I would need to do this to I'm assuming. If you have some time could you walk me through it?
  • 8.  RE: Render View Text Editing in Other Scenes
    Posted 02-17-2016 19:51
    Yes. You'd have the same script in all 14 text objects. The only difference would be that each text object connects to a different text object in the renderview scene. XPression will easily handle this.
  • 9.  RE: Render View Text Editing in Other Scenes
    Posted 02-18-2016 19:43
    @garner I'm happy to hear it will be easily handled. However I'm not sure how to implement it. Could someone supervise walking through it?
  • 10.  RE: Render View Text Editing in Other Scenes
    Posted 02-19-2016 21:26
    Here's a sample project where you can edit a text object in a renderview from the invisible published text in the primary scene.
    http://transfer.rossvideo.com/f/4e83d9ae1
  • 11.  RE: Render View Text Editing in Other Scenes
    Posted 01-06-2017 23:14
    @garner i have this problem too. You can send for me this project too? Thanks!
  • 12.  RE: Render View Text Editing in Other Scenes
    Posted 01-06-2017 23:17
  • 13.  RE: Render View Text Editing in Other Scenes
    Posted 01-06-2017 23:28
    Thanks! Cool! 😊
    So quickly!
