Here's an image that might better explain. The white bar with the crawling ticker needs to move down on the y axis so it disappears behind the gray bar. This will be controlled by transition logic depending on a set rule.
62 Auriga DriveNepean, OntarioCanada, K2E 7W6
Phone+1 613 228-0688Emailcommunity@rossvideo.com
LoginJoinHelp/FAQEventsrossvideo.com
Terms and ConditionsPrivacy PolicyDMCA Policy
