  • 1.  Xpression Animation pause and continue
    Posted 08-12-2015 19:45
    I have an animation that takes the graphic in Xpression (pushing up through a mask). How can I animate the out? I need the animation to run backwards. This forum says to have a continuous animation for the in and out with a pause in between. How would I do that?
  • 2.  RE: Xpression Animation pause and continue
    Posted 08-12-2015 20:03
    You can just drag the animation controller that has your in effect onto the scene director a second time. Then right click the animation controller and choose "reverse direction". That will play the animation backwards.
    You can put a pause event on the scene director between the two animation controllers so it will pause and wait before it plays out.
  • 3.  RE: Xpression Animation pause and continue
    Posted 08-12-2015 20:30
    Is there a way to get it to automatically go offline once the animation finishes?
  • 4.  RE: Xpression Animation pause and continue
    Posted 08-12-2015 20:37
    Yes, just add a take offline event to the end of the scene director.
