Hi All,
I'm using Xpression Studio v7.0 build 3798. Also using Xpression Datalinq Server v7.0 build 3798.
I'm working on a show that is pulling poll numbers via an http link that is formatted as an xml. Which works perfectly.
My small issue is when I come in the next week and call up the poll graphic it will not update to the new poll numbers that are in the xml link; even though everything is still running. Even when I browse the xml link in the Datalinq Server it shows the previous weeks poll results. Restarting the software does not correct the problem. It's not until we restart the machine through windows does the Datalinq Server start to see the new poll results. Then works perfectly for the rest of the day.
I was just curious if anyone has run into this? I've never encountered this before and want to find out why it is happening. Anyone have any ideas?
