  • 1.  Renderview cannot render a view in the current scene?
    Posted 08-19-2016 18:46
    Can a renderview not render a texture from the current scene?
  • 2.  RE: Renderview cannot render a view in the current scene?
    Posted 08-22-2016 11:01
    What do you mean ?
  • 3.  RE: Renderview cannot render a view in the current scene?
    Posted 08-22-2016 14:10
    So, imagine off in space somewhere I create a little 3D scene with some cubes and spheres; it's off the normal viewing area so you don't see it. I create a new perspective camera to view just that little scene. In template mode, I can tell the viewport to use that camera and I can see my scene and it's all good. Then I switch back to the default camera, create a quad, and create a material that uses the renderview of that new perspective camera I created, and map that material to the quad. I cannot see anything.
    I can create a new scene within the same project, create a quad and map the same material (because it's shared in the project) to that quad - and I can see the camera's view of those objects mapped onto a quad.
    So it doesn't work when I try to make a self contained scene to do this, it only works if the renderview selects a different scene. It would be cool to be able to accomplish everything in one scene.
  • 4.  RE: Renderview cannot render a view in the current scene?
    Posted 08-22-2016 14:32
    Which version have you ? Because you can put a quad with a renderview on it of another camera in the same scene...
  • 5.  RE: Renderview cannot render a view in the current scene?
    Posted 08-22-2016 14:43
    I will try again, starting from scratch.
  • 6.  RE: Renderview cannot render a view in the current scene?
    Posted 08-22-2016 15:07
    I'm sorry - it worked just fine. I tried doing it on a different laptop; perhaps it was a hardware thing with a non-supported graphics card.
  • 7.  RE: Renderview cannot render a view in the current scene?
    Posted 08-22-2016 15:41
    Now there is another problem, however - if I have multiple renderviews, they each seem to trigger any animation - so the second renderview of the same set of objects is animating faster.
  • 8.  RE: Renderview cannot render a view in the current scene?
    Posted 08-22-2016 15:42
    Oh... actually, it works on playout, but the Layout view gets out of whack, so it's not the end of the world, but it's not quite right, either.
