  • 1.  Adjust audio that is part of a video file
    Posted 12-25-2018 00:00
    Is there a way to adjust the audio level on a video clip? I tried dragging the clip to an audio track and keyframing but it had no apparent effect.
  • 2.  RE: Adjust audio that is part of a video file
    Posted 12-26-2018 00:20
    I've always rendered video and audio separately with the understanding that video clips with audio could not be adjusted...maybe in a newer version, hunh?
  • 3.  RE: Adjust audio that is part of a video file
    Posted 12-27-2018 18:20
    That might be the way to go
  • 4.  RE: Adjust audio that is part of a video file
    Posted 01-02-2019 17:15
    You can set the volume level of a video shader via a script by calling these methods and applying a value between 0 and 1 to them,
    1 = 100% volume
    0.5 = 50% volume
    0 = 0 % volume
    xpVideoShader.GetVolumeLevel
    xpVideoShader.SetVolumeLevel
