I've created a project that uses a crawl where each text item in the crawl is a separate scene, and within each scene there is a text object that is using a Datalinq based on an excel workbook. I load the crawl out of my XPression, and it plays each scene in sequence, and in between each scene I have another scene that has a logo that appears, and separates each text item in the crawl.
I edited my Excel file, and removed one of the entries, as it was no longer needed in the crawl. My issue involves editing my Excel file, and that the scenes in my crawl are not updating the text they are tied to via the Data Source setup. I've included a screen grab to help explain how this is setup. You'll see that the row number in the datalinq tab isn't equal to the actual row number (column B) on the Excel file, which leaves the text taking it's information from the row that it was setup assigned to when it was initially setup. If the Datalinq updated it's content each time the project was open, then any changes I make to the Excel file, before I open the project, would update upon open. Am I missing a step here, or is this not a function available in the setup I've created here? Thanks
