  • 1.  Xpression MOS Server Exporting?
    Posted 01-29-2016 21:06
    Is there away to make our Xpression MOS server export a list of the MOS objects on our Xpression playlist to a text document? We have use a Studio & Blue Box with a MOS Server that talks to ENPS 7 and run our automation through Overdrive if that helps.
  • 2.  RE: Xpression MOS Server Exporting?
    Posted 02-02-2016 02:37
    It's not possible to export the MOS rundowns from the XPression Gateway.
    However, you can export all the MOS graphics from the Sequencer on Studio - see attached picture.
    You can export as .txt .xml or .csv.
    This export all the take items in your sequencer. Which would be all the MOS graphics you have in any activated rundowns.
