  • 1.  [ASK] Feature Like 'News Editable' on Inscriber VMP?
    Posted 07-02-2014 12:19
    Good Night Every body ...
    Is There any feature in Xpression like "New editable" on Inscriber VMP?
    I use News Editable on Credit Title every day to change Crew Name wich consist about 30 name or more.
    I change one by one without type it. but in Xpression we did not found this feature. I have to type it one by one.
    News Editable is simple feature but very helpfull.
    Thank You for your help.
    *)Note:
    -I saw the tutorial about datalinq, Unfortunately we bought Xpression without datalinq.
    -I Try it with widget, but It did not work.
  • 2.  RE: [ASK] Feature Like 'News Editable' on Inscriber VMP?
    Posted 07-02-2014 15:57
    You can use the widget "List" for that, why did you say it not works ? What happen ?
  • 3.  RE: [ASK] Feature Like 'News Editable' on Inscriber VMP?
    Posted 07-03-2014 23:21
    Thank You For Replay Vincent ...
    I try widget to change Name of Crew but it change all the name on the same category.
    I mean like this, I save several catogory for This.
    For Example On Widget I made Category "Camera Person"
    Asep
    Didin
    Dadan
    etc.
    On Credit title
    I Have to change The Name of Crew.
    Camera Person
    Dadan
    Didin
    Asep
    When i change one of the name above than all change,
    ex: I Change to Dadan and all name will be like this:
    Camera Person
    Dadan
    Dadan
    Dadan
    How you do this? Do I miss something?
    Thank You.
  • 4.  RE: [ASK] Feature Like 'News Editable' on Inscriber VMP?
    Posted 07-07-2014 20:49
    Hi Gilar,
    The Text Widget is only for storing a text list and then applying a single line from the list to a text object. Changing the widget's text will change the text of ALL text objects linked to it.
    If you wanted to use the text widget for your solution you would need one text widget per text object you want to populate with a name. Ex. 30 peoples names = 30 text widgets
    Unfortunately the functionality you are looking for is a feature of Datalinq.There is no easy way to auto fill text fields in XPression without Datalinq.
  • 5.  RE: [ASK] Feature Like 'News Editable' on Inscriber VMP?
    Posted 07-08-2014 12:42
    Ok Garner... Thank you for your Answer....
    Best Regards
    Gilar Kadarsah
