  • 1.  Roadmap for Elgato Stream Deck integration.
    Posted 10-12-2017 02:21
    Just saw this post over in the Dashboard forum (https://discussions.rossvideo.com/forum/default-forum-gc1/dashboard-gc43/13839-custom-hardware-panel-using-elgato-stream-deck) and would be interested to know if/when there is likely to be support within XPression for the Elgato Stream Deck for playout from the Sequence tab? Seems like a really neat little unit...
  • 2.  RE: Roadmap for Elgato Stream Deck integration.
    Posted 10-12-2017 14:28
    I have no experience using XPression beyond just seeing it in action, but if it's possible to create a custom panel in Dashboard to do the actions you want in XPression, then I can show you how to set up the Stream Deck to trigger the Dashboard panel.
  • 3.  RE: Roadmap for Elgato Stream Deck integration.
    Posted 10-12-2017 21:02
    Can't you just map XPression keyboard shortcuts to the Stream Deck to trigger the XPression Sequencer?
    What support needs to be added?
