  • 1.  Mirroring Scenes... or Layers/Elements
    Posted 12-18-2018 21:21
    Just whipped up an OTS in our new graphics package and was wondering if it is possible to mirror the elements in the scene rather than rebuild and reposition everything. Any tips or tricks to optimize a repetitious workflow would be greatly appreciated. Even if they aren't relevant to this particular issue.
  • 2.  RE: Mirroring Scenes... or Layers/Elements
    Posted 12-19-2018 01:59
    Assemble your elements in a Group object...duplicate the group and rotate 180 degrees on the y-axis or change the x-scale to a negative number. Things like text you'll need to go into the group and do the opposite to them.
  • 3.  RE: Mirroring Scenes... or Layers/Elements
    Posted 12-19-2018 20:13
    Checking the Double Sided checkbox in the Material Editor, Lighting/Fill section might do it.
