  • 1.  Visual logic and Scene Director change number problem
    Posted 03-21-2017 21:13
    Hey! I'm wanting to do an effect where when I increase the value, the last value stays, goes down and the new value comes in. I've created the effect but the timing is wrong, so you see the transition but it jumps to the old number since there is a stop effect which need to be there to reset the transition for the next number. Any suggestions to how I may solve this problem?
    Link to project: https://www.jottacloud.com/p/hermangud/4d399267dd6f4b3cbb5cd547388a9219
  • 2.  RE: Visual logic and Scene Director change number problem
    Posted 03-22-2017 14:58
    Found a solution. In the stop event at the end of the scene director, I set jump 1 frame relative and move the event one frame forward.
