  • 1.  Script Editor Not Working
    Posted 05-21-2014 19:23
    So I had a bunch of scripts written up for several templates that were working fine, but now they do nothing. The only change I can think of is we updated to Xpressions 5.5 recently. I know 5.5 has Visual Logic on there and I was thinking maybe it is overriding the scripts. Please help.
  • 2.  RE: Script Editor Not Working
    Posted 05-21-2014 19:33
    Kevin,
    Please tell us what version you upgrade from and upload your project somewhere so we can check the scripts.
    Visual logic will not override scripts.
  • 3.  RE: Script Editor Not Working
    Posted 05-21-2014 20:06
    We were running Xpressions 5.0 before. I know that the scripts are good because they were ALL working fine before and now NONE of them are working. I should note that this is on Designer where we build our templates. We then publish them to our server and then they are run out through Studio on air. Both Studio and Designer were updated to 5.5 along with the rest of our Xpressions products (BlueBox, MOS gateway, and ActiveX). Our templates that were published before the update still work, but we can't update any of our projects until this is resolved.
  • 4.  RE: Script Editor Not Working
