  • 1.  XPression Keyboard Take Button Not Working
    Posted 11-05-2018 16:47
    I'm using the default keyboard map layout and at one point the take key on my XPression keyboard was working and I think I inadvertently did something to change that. If I make a new shortcut save file and make a new global hotkey for enter = take online, that works but also doesn't let me use enter to commit any changes on dialog boxes since its not specific to the sequencer and it's a global. Any thoughts?
  • 2.  RE: XPression Keyboard Take Button Not Working
    Posted 11-05-2018 17:01
    Does everything work correctly if you set your keyboard map to default?
  • 3.  RE: XPression Keyboard Take Button Not Working
    Posted 11-05-2018 17:06
    Everything else but the Take button haha.
  • 4.  RE: XPression Keyboard Take Button Not Working
    Posted 11-05-2018 17:09
    When your keyboard map is set to default you can't take items online or hit enter in dialog boxes?
  • 5.  RE: XPression Keyboard Take Button Not Working
    Posted 11-05-2018 17:14
    No, I just can't use it for take online in XPression. It works as a regular key for committing dialog boxes or typing in other programs. I misunderstood your earlier question.
  • 6.  RE: XPression Keyboard Take Button Not Working
    Posted 11-05-2018 17:25
    Does the take next key work normally?
  • 7.  RE: XPression Keyboard Take Button Not Working
    Posted 11-05-2018 17:31
    Yep, as far as I can tell the rest of the shortcuts work properly on the default layout. I'd planned to use that until I can figure out the issue, will just have to adjust my muscle memory.
  • 8.  RE: XPression Keyboard Take Button Not Working
    Posted 11-05-2018 20:00
    [I]FIXED. Originally I made a new hotkey on a custom profile to add video materials faster and I made that hotkey CTRL+A, and I guess CTRL+A does something to get rid of the take functionality so I ended up hitting CTRL+A again and it now works.[/I]
    Edit: Nevermind, it's been a long day.
