I've written a web service that generates an image based live data.
In expression, we can assign the image a link, like
http://myserver.mycompany.com/generate_image?id=1
The problem is that once Xpression gets the image, it doesn't seem to want to update. If I type the URL directly in a browser, I always see the latest version of the image, but in Xpression, I always see the image as it was the first time Xpression grabbed it.
In other words, it seems like it's caching the image. That's actually OK, since it takes a long time (up to five seconds or so) for the server to return an image (it's built using a fairly complex set of data and calculations), but we need to be able to periodically force it to update. Is it possible?
