  • 1.  Reflection Map sizing
    Posted 06-25-2015 18:58
    Hi, I am new to the forum and have been training on Xpression over the last few months. My question is - is there a way to size the reflection when adding the reflection map to a material. For example, I create a quad and it is 500 x 500 px and then I create a material with a reflection map to add to it (say with a sports team logo) however the logo reflecting is very large and it is tough to see what the reflection actually is in the quad.
    Many thanks,
    Jason
  • 2.  RE: Reflection Map sizing
    Posted 06-26-2015 20:47
    In version 5.9 and above you should have the ability to edit the Texture Coordinates of the reflection map shader, and using the texture scale you should be able to adjust the reflection map texture.
    What version are you running?
  • 3.  RE: Reflection Map sizing
    Posted 06-26-2015 20:57
    Thanks Brian, that helps a lot. We are running v3.6 however soon to be upgrading.
