Hey guys,
I am in the process of trying to migrate scripts from an older version of a scene to a newer one. As an example in once scene - a lower 3rd with up to 5 player stats, there is a script at the scene level:
dim Keys as xpDatalinqKeys
Dim Key(5) as xpDatalinqKey
dim Cat(5) as xptextObject
dim i as integer
Engine.DebugMessage("test", 1)
Self.GetDatalinqKeys(Keys)
For i = 1 to 5
Keys.GetKeyByName("STAT" & i, Key(i))
Self.GetObjectByName("CAT-" & i, Cat(i))
Cat(i).text = Key(i).AsString
Next
This compiles successfully - great!
Then further down in the hierarchy, there are scripts on the category names, such as:
CatTrans(scene, text)
These do not compile successfully, returning the following message:
1,0: BC30451 Name'CatTrans' is not declared.
I have looked everywhere I can think of in the both the scene, and the project's setup page for another piece of script in which said needed declaration is made, but to absolutely no avail. I do have all of the relevant stats successfully datalinqed up, so I am at something of a loss,
Any ideas?
- Willie
