I have a lower third that receives a score from an Excel spreadsheet. That works fine. However, they have requested that I add a second score field to the layout and update all the takes that were already populated in sequencer. I have added dummy data to the second field in the spreadsheet, linked all the fields and saved it. Despite clicking "refresh datalinqs" in the shortcut menu for each take it does not see the updated value in the spreadsheet.
Is this a change that would require the take to be removed and re-added to sequencer?
How can I test the data in the second score field?
I feel like this should be simple and straight forward. I have to have this done tonight. Thanks again to the community for the help.
Chase
