  • 1.  Sequence Playlist auto advance to next scene
    Posted 12-13-2018 20:57
    On our main Xpression, while in Sequence mode, when I take a scene offline it continues to highlight that take item. However, on our Xpression Designer (on another computer), after taking a scene offline, it automatically advances to the next take item. I want it to remain on the same take item until I manually cue a different one. I looked in Edit>Preferences, but cannot find a way to change this. Am I missing something or is this a setting that cannot be changed?
  • 2.  RE: Sequence Playlist auto advance to next scene
    Posted 12-14-2018 12:01
    A preference was added to version 8.7 to control this advancement.
    However, until that version is released, try mapping a "Take Offline" command using the Keyboard Mapping shortcut, and assign it to the Minus key on the keyboard.
    That should allow you to control whether the Take Offline/Minus key will advance or not.
  • 3.  RE: Sequence Playlist auto advance to next scene
    Posted 12-17-2018 12:07
    This works! Thank you.
