  • 1.  Script Editor Text Object Tabs (Alignment and Position)
    Posted 04-27-2014 15:30
    Is there a way to write a script that edits a text object's tab? I'm thinking it would be similar to the ".posX" and what not. I'd like to be able to adjust the position and alignment of the different Tab Points within the text object.
  • 2.  RE: Script Editor Text Object Tabs (Alignment and Position)
    Posted 04-28-2014 18:35
    .SetTabAlign and .SetTabPosition
    Try to have a look at the API doc, everything is inside ! (in help folder of Xpression)
