I am trying to figure out how I can force a number entry in a leaderbord to have a decimal when a number is entered, even if it is a whole number. IE: 7 needs to display as 7.0
I have seen in other posts that you can do it by right clicking on the text item and applying a script. I am unsure what scripting language to use OR how to preview the result to ensure it is functioning properly.
This is one post I saw that seemed to do something similar.
One other scenario I have that is basically the same issue is that I have one leaderboard where I need to force it to display 2 numbers after the decimal place. Despite the value in the spreadsheet being 2 IE 8.75 it only displays 8.7
Thanks for any help.
