Redefine the clock widget to start when put online. In Visual Logic, you may need to link SceneDirector1.Events.OnPlay to SceneDirector1.Actions.Play. If your sound effect doesn't work in the render, you may need put to the sound effect audio file on the SceneDirector timeline audio track. To render, put the scene in the sequence, right click on it and select Export Take Item to > Video.
