  • 1.  Datalinq: Excel Source Stopped Working After Windows Update
    Posted 10-12-2017 18:10
    [h=1]Cause of Issue:[/h]
    Microsoft released updates to MS office and access jet driver early October that may cause issues with Datalinq excel sources.
    [h=1]Issue Symptoms:[/h]
    • After doing a Windows Update, excel data sources no longer work.
    • Testing connect results in a "Failure: Unexpected error from external database driver (1)"�
    [h=1]Issue Fix:[/h] [LIST=1]
    ***32 bit must be installed, XPression cannot use the 64 bit version***
    2.Once downloaded configure the data source and change the connection string values to and save
    Provider=Microsoft.ACE.OLEDB.12.0;
    Data Source=C:\Users\bderry\Test.xls;
    Extended Properties="Excel 12.0;HDR=Yes;IMEX=1";
    Picture for reference:
    Old Source:
    New Source:
  • 2.  RE: Datalinq: Excel Source Stopped Working After Windows Update
    Posted 11-15-2017 18:26
    Microsoft has resolved the issue as of November 14th. The JET driver should again be functional.
    https://support.microsoft.com/en-us/...date-kb4048957
