  • 1.  v5.11 vs 5.5
    Posted 10-02-2014 23:32
    Hi
    I currently am working on a v5.11 xpression. Many of my graphics are built thru scripting. I know that v5.5 version has the new feature, visual logic block. If I upgrade to v.5.5, will it affect my graphics?
  • 2.  RE: v5.11 vs 5.5
    Posted 10-03-2014 05:47
    Hi Eilen,
    The Visual Logic and Script Event systems are completely separate from each other. They can both work at the same time and are not connected.
  • 3.  RE: v5.11 vs 5.5
    Posted 10-03-2014 12:23
    If you use the Layer Object in your graphic, double check that the order of the layers is correct when you upgrade to 5.5. There was a new feature added in 5.5 that lets to rearrange the rendering order of the layers. Sometimes the render order in 5.11 would change on occasion, so in 5.5 you can force the order to what you expect.
    There is a new tab in the Object Inspector to specify the order.
